Einleitung
We will replace the hard drive in this guide. The only necessary tools are a screwdriver and a spudger/plastic opening tool.
Was du brauchst
Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
Disconnect the three cables connecting the back panel ports to the motherboard.
Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
Gently wiggle the third connector out of its socket.
Remove the four 5.0 mm Phillips #1 screws on the outer casing of the hard drive.
Remove the four 3.5 mm Phillips #1 screws on the edges of the outer casing, two on each side.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
