Zum Hauptinhalt wechseln
Einleitung
This guide will demonstrate how to remove the pair of speakers. This process is straightforward, and no special tools are necessary.
  1. Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away. Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information. Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the grey scuff guard at the bottom of the PC by pressing down on it, and pulling it away.
    • Lift the hinge and remove the grey rubber tabs on either side of the PC’s model information.
    • Remove the two 7.62mm Phillips #1 screws beneath the rubber tabs under the hinge and the four 7.62mm Phillips #1 screws where the scuff guard was removed.
    • Remove the two 4.74mm Phillips #1 screws under the hinge (near the hinge joints) and a 4.74mm Phillips #1 screw under the handle.
  2. Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel. We recommend that you start prying the panel where the scuff guard was removed. Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Use 1-2 plastic opening tools or nylon spudgers to firmly pry open the back panel.
    • We recommend that you start prying the panel where the scuff guard was removed.
    • Prying the back panel will cause loud popping noises. This is just the sound of the clips that hold the back panel to the PC popping off.
    • Using excess force while prying can break the clips that hold the back panel and can damage the ports on the side of the PC.
  3. Disconnect the three cables connecting the back panel ports to the motherboard. Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out. Gently wiggle the third connector out of its socket.
    • Disconnect the three cables connecting the back panel ports to the motherboard.
    • Flip up the locking latch holding the two ribbon cables with a plastic opening tool and pull the cables out.
    • Gently wiggle the third connector out of its socket.
  4. The two in-house speakers are located near the sides of the device with the motherboard in between. Remove the two 2.35 mm Phillips #1 screws from each speaker.
    • The two in-house speakers are located near the sides of the device with the motherboard in between.
    • Remove the two 2.35 mm Phillips #1 screws from each speaker.
  5. The two speakers are attached to each other with a cord that is threaded along the side of the casing. Gently pull the wire out The cord is secured under two pieces of tape with multiple other wires. Make sure that you only remove the wire connecting the speakers.
    • The two speakers are attached to each other with a cord that is threaded along the side of the casing. Gently pull the wire out
    • The cord is secured under two pieces of tape with multiple other wires. Make sure that you only remove the wire connecting the speakers.
    • Keep in mind that when replacing the wires, you will need to secure the tape again. Accordingly, be careful not to tear the tape when peeling it.
  6. Pull the cord attached to the speaker out of the motherboard
    • Pull the cord attached to the speaker out of the motherboard
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Erich Fenczik Warnock
193 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S17-G5, Livingston Spring 2018 Mitglied von Cal Poly, Team S17-G5, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G5
4 Mitglieder
16 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 77
