Zum Hauptinhalt wechseln
ASUS Q302L Display Replacement
Was du brauchst
  1. ASUS Q302L Display Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Display Replacement: Schritt 2, Bild 1 von 3 ASUS Q302L Display Replacement: Schritt 2, Bild 2 von 3 ASUS Q302L Display Replacement: Schritt 2, Bild 3 von 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Display Replacement: Schritt 3, Bild 1 von 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Display Replacement, Battery: Schritt 4, Bild 1 von 1
    • Use a Phillips #0 screwdriver and remove all five 5 mm screws securing the battery.
  5. ASUS Q302L Display Replacement: Schritt 5, Bild 1 von 3 ASUS Q302L Display Replacement: Schritt 5, Bild 2 von 3 ASUS Q302L Display Replacement: Schritt 5, Bild 3 von 3
    • Gently wedge a plastic opening tool under the connector.
    • Pry only on the connector not the socket itself or you risk damage to the motherboard.
    • Carefully lift the connector up away from the socket to disconnect it.
  6. ASUS Q302L Display Replacement: Schritt 6, Bild 1 von 2 ASUS Q302L Display Replacement: Schritt 6, Bild 2 von 2
    • Once the screws and connector are removed, simply pull out the battery from its place.
  7. ASUS Q302L Display Replacement, Display: Schritt 7, Bild 1 von 2 ASUS Q302L Display Replacement, Display: Schritt 7, Bild 2 von 2
    • Use a Phillips #00 screw driver to remove the five 10mm screws at the hinges.
  8. ASUS Q302L Display Replacement: Schritt 8, Bild 1 von 3 ASUS Q302L Display Replacement: Schritt 8, Bild 2 von 3 ASUS Q302L Display Replacement: Schritt 8, Bild 3 von 3
    • Peel back the tape and remove the two connectors.
  9. ASUS Q302L Display Replacement: Schritt 9, Bild 1 von 2 ASUS Q302L Display Replacement: Schritt 9, Bild 2 von 2
    • Pull up on the black tab to remove the connector that connects to the motherboard.
    • Unplug the hard drive cable from the hard drive.
    • Carefully remove the cables from the track that they run through.
  10. ASUS Q302L Display Replacement: Schritt 10, Bild 1 von 2 ASUS Q302L Display Replacement: Schritt 10, Bild 2 von 2
    • Carefully remove the display from the rest of the laptop.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
IUPUI, Team S2-G4, Harley Spring 2019 Mitglied von IUPUI, Team S2-G4, Harley Spring 2019
IUPUI-HARLEY-S19S2G4
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 13
Insgesamt: 1,141
