Zum Hauptinhalt wechseln
ASUS Q302L Fan Replacement
Was du brauchst
  1. ASUS Q302L Fan Replacement, Back Case: Schritt 1, Bild 1 von 1
    • Make sure the laptop is disconnected from a power supply and is TURNED OFF.
    • Use a Phillips #0 screw driver to remove all ten 10 mm screws around the back of the laptop.
  2. ASUS Q302L Fan Replacement: Schritt 2, Bild 1 von 3 ASUS Q302L Fan Replacement: Schritt 2, Bild 2 von 3 ASUS Q302L Fan Replacement: Schritt 2, Bild 3 von 3
    • Wedge a plastic opening tool under the rear case near the hinge.
    • Pry around the outer edge to release the plastic clips holding the rear case to the laptop.
  3. ASUS Q302L Fan Replacement: Schritt 3, Bild 1 von 1
    • Once the cover is free from all the clips, remove the cover from the laptop.
  4. ASUS Q302L Fan Replacement, Fan: Schritt 4, Bild 1 von 2 ASUS Q302L Fan Replacement, Fan: Schritt 4, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove all three 4mm screws around the fan.
    • Using the same screw driver, remove the four 4mm screws from the part of the fan that is above the processor.
  5. ASUS Q302L Fan Replacement: Schritt 5, Bild 1 von 3 ASUS Q302L Fan Replacement: Schritt 5, Bild 2 von 3 ASUS Q302L Fan Replacement: Schritt 5, Bild 3 von 3
    • Gently wedge two plastic prying tools on both sides of the black part of the connector.
    • Carefully pull out the connector from its socket.
  6. ASUS Q302L Fan Replacement: Schritt 6, Bild 1 von 2 ASUS Q302L Fan Replacement: Schritt 6, Bild 2 von 2
    • Once all screws and the connector are removed, you can safely pull the fan out of its place.
Abschluss
USF Tampa, Team S13-G4, Cagle Spring 2017 Mitglied von USF Tampa, Team S13-G4, Cagle Spring 2017
USFT-CAGLE-S17S13G4
3 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 783
