Zum Hauptinhalt wechseln
ASUS Q324UA-BHI7T17 CPU Fan Replacement
Was du brauchst
  1. ASUS Q324UA-BHI7T17 CPU Fan Replacement, Battery: Schritt 1, Bild 1 von 1
    • Remove all 10 Phillips screws on the backplate.
    • All 10 screws are 0.55 inches and 20 mm in diameter.
  2. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 2, Bild 1 von 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the backplate using the plastic opening tool.
  3. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 3, Bild 1 von 1
    • Locate the battery near the bottom.
  4. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 4, Bild 1 von 1
    • Next, lift up the battery connector from the laptop in the upper left side of the battery, using tweezers or spudger.
    • Make sure to complete this step with caution, because if the battery is not unplugged, the motherboard may shock you.
  5. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 5, Bild 1 von 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 5, Bild 2 von 2
    • Remove the six screws holding in the battery with a Phillips #0 screwdriver.
    • Once battery is lifted out and removed, proper dispose of the old battery.
    • Each screw is 0.5 cm in length and 0.5 cm in diameter.
  6. ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: Schritt 6, Bild 1 von 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement, CPU Fan: Schritt 6, Bild 2 von 2
    • Using a Phillips #0 screwdriver remove the six screws holding the CPU Fan and Heatsink in place.
    • All six screws are 0.4 cm in length and have a 0.5 cm head diameter.
  7. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 7, Bild 1 von 2 ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 7, Bild 2 von 2
    • Next, carefully remove the sliding connector that connect the CPU Fan and the laptop together using the tweezers.
  8. ASUS Q324UA-BHI7T17 CPU Fan Replacement: Schritt 8, Bild 1 von 1
    • Remove the CPU Fan and Heatsink by simply lifting upwards.
Abschluss
Scott Santiago
534 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team S1-G1, Simcock Fall 2017 Mitglied von UMass Dartmouth, Team S1-G1, Simcock Fall 2017
UMASSD-SIMCOCK-F17S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 5
Insgesamt: 1,038
