Einleitung
If the display of your device is cracked or broken, use this guide to replace it.
Was du brauchst
Remove all ten 5mm crews on the backplate using a Phillips #0 Screwdriver.
Remove the back plate by prying from side.
Use a pair of tweezers to disconnect the two black rectangle connections.
Eine weitere Person hat diese Anleitung absolviert.
