Einleitung
If the mouse isn’t properly tracking your movements, the trackpad may be faulty. Use this guide to replace the trackpad in your device.
Was du brauchst
Remove all ten 5mm screws from the backplate using a Phillips #0 Screwdriver.
Disconnect the battery from the laptop in the upper left side of the battery, using tweezers.
Remove the six 5 mm screws holding the battery using a Phillips #0 screwdriver.
Remove the two 5mm screws holding in the trackpad using a Phillips #0 screwdriver.
