Einleitung
If your laptop can no longer read CDs/DVDs, the optical drive may need to be replaced. Use this guide to remove and replace the optical drive.
Was du brauchst
Turn off the laptop.
Disconnect the charging cable from the laptop.
Flip the laptop over so that it is upside down.
Orient the laptop so that the battery is away from you.
Find the tab in the top left corner. With one finger, pull the tab to the left to the unlocked position.
While holding this tab in the unlocked position, gently pull the battery away from you.
Locate and remove the 8mm PH0 screw near the middle of the laptop.
On the left side of the section, there is a metal tab. Using a metal opening tool, push the tab as far as possible to the left.
Once the optical drive is sticking out of the left side of the laptop, slide it smoothly out of its slot.
