Einleitung
It is a common issue among ASUS Q400A laptops to refrain from charging. Among battery and charger issues, it is likely that the power jack isn't operating correctly. The following is a guide explaining how to gain access to the power jack for replacement.
Was du brauchst
Flip laptop over with the battery facing toward you.
Slide both tabs with the lock/unlock symbol, near the battery on the right of the notebook, to the unlock position.
Grab the top edge of the battery & lift upward to relieve the battery from its slot.
Remove the one black 8mm Phillips #0 screw.
Lift and remove the bottom cover panel using the plastic opening tool.
Remove the single silver 8mm Phillips #0 screw.
Remove the three 8mm Phillips #0 screws.
Remove the seven black 8mm Phillips #0 screws around the perimeter.
Remove the two silver 8mm Phillips #0 screws that are under the battery.
Flip the device right-side up and pry up the keyboard and touchpad gently using both hands.
Release the ZIF (zero insertion force) connector using a plastic spudger.
Remove the ribbon cable by hand from the ZIF connector.
Lift the motherboard gently to completely remove this component from the device.
Detach Audio Cable gently by hand and you have now access to replace the power jack.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
