Einleitung
The wifi card is what lets you connect to the world wide web, and there are plenty of people who would find a computer without one to be absolutely useless. That’s why if there is ever a problem with it, it’s important to get it fixed, wifi troubles tend to be very annoying for most users such as when the computer’s connection is slow, or it can’t even recognize nearby networks. This guide will take you step by step on how to replace the Wifi Card of your ASUS Q405U
Was du brauchst
Using the Phillips #1 screwdriver, remove eleven (11) 1.5 mm screws from the back cover.
Pull the back cover off of your laptop. Use a spudger to help pry it off of the device.
Disconnect the 4 wires attached from the keyboard side of laptop to the screen side of laptop by pulling them out of their sockets on one end (as shown in picture).
Using the Phillips #1 screwdriver, remove the four 1.5 mm screws securing the battery to the device.
Once all screws are removed, lift the battery out from the base of the computer.
Using the Phillips #1 screwdriver, remove the 0.8 mm screw securing the Wi-Fi card to the device.
