Einleitung
When replacing a motherboard, it's crucial to select a compatible replacement and consider factors like form factor, chipset, and socket type. Additionally, users should ensure they have proper technical knowledge or seek professional assistance, as motherboard replacements can be complex and may require transferring components from the old motherboard to the new one.
Was du brauchst
Remove ten 2 mm screws using a Phillips #0 screwdriver.
Remove the screw in the center using a T4 Torx screwdriver.
Use an iFixit opening tool to pry open the back panel.
Unhinge the fan cable using your fingers or a pair of tweezers.
Remove the battery from its slot.
Use a Phillips #0 screwdriver to remove the six 2 mm fan screws.
Use a Phillips #0 screwdriver to remove the five 2 mm heatsink screws.
Warped Screw
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Disconnect white and black antennae cables.
Carefully lift heatsink upward using a Ifixit opening tool or Fingers pull fan out from under the heat sink.
Disconnect the white ribbon cable from the connection lever using a Jimmy.
Use a Phillips #0 screwdriver to remove the four 2 mm screws that secure the motherboard.
Using opening tool, lift up on both ribbon cable clamps, releasing the connection point.
