Zum Hauptinhalt wechseln
ASUS Q536F Screen Replacement
Was du brauchst
  1. ASUS Q536F Screen Replacement, Back Panel: Schritt 1, Bild 1 von 2 ASUS Q536F Screen Replacement, Back Panel: Schritt 1, Bild 2 von 2
    • Remove ten 2 mm screws using a Phillips #0 screwdriver.
    • Remove the screw in the center using a T4 Torx screwdriver.
    • Use an iFixit opening tool to pry open the back panel.
    • It's normal to hear some cracking, but proceed with caution.
  2. ASUS Q536F Screen Replacement, Display Assembly: Schritt 2, Bild 1 von 1
    • Remove the six 2 mm screws from the hinges using a Phillips #0 screwdriver.
  3. ASUS Q536F Screen Replacement: Schritt 3, Bild 1 von 3 ASUS Q536F Screen Replacement: Schritt 3, Bild 2 von 3 ASUS Q536F Screen Replacement: Schritt 3, Bild 3 von 3
    • Using your fingers, unplug the two power cables connecting the display to the motherboard.
    • Remove the display assembly from the laptop.
  4. ASUS Q536F Screen Replacement, Screen: Schritt 4, Bild 1 von 3 ASUS Q536F Screen Replacement, Screen: Schritt 4, Bild 2 von 3 ASUS Q536F Screen Replacement, Screen: Schritt 4, Bild 3 von 3
    • Potential for device damage: Beneath the screen border is a sticky adhesive. Take your time and exercise caution when removing to avoid damaging it.
    • Use an iOpener to help loosen the adhesive on the screen.
    • Gently pry the bottom right corner of the screen's border and remove the sticky screen cover.
    • Use the opening tool around the entire display to ensure you cut as much adhesive as possible.
  5. ASUS Q536F Screen Replacement: Schritt 5, Bild 1 von 1
    • Carefully remove the screen from the rest of the display.
    • The new screen should come with the sticky adhesive.
Abschluss
Adra Ledward
557 Reputation
5 Anleitungen geschrieben
Gateway, Team 88-8, Gonzalez Fall 2023 Mitglied von Gateway, Team 88-8, Gonzalez Fall 2023
GCC-GONZALEZ-F23S88G8
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 25
Insgesamt: 170
