Zum Hauptinhalt wechseln
ASUS R554L Battery Replacement
Was du brauchst
  1. ASUS R554L Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Flip the laptop so the bottom is facing upward.
    • Remove ten screws using a Phillips #0 screwdriver.
  2. ASUS R554L Battery Replacement: Schritt 2, Bild 1 von 3 ASUS R554L Battery Replacement: Schritt 2, Bild 2 von 3 ASUS R554L Battery Replacement: Schritt 2, Bild 3 von 3
    • Using your fingertips, carefully pull the backplate in an upright direction.
    • Continue along the edges until the backplate is fully removed.
    • It's normal to hear cracking while pulling up on the plate.
  3. ASUS R554L Battery Replacement: Schritt 3, Bild 1 von 3 ASUS R554L Battery Replacement: Schritt 3, Bild 2 von 3 ASUS R554L Battery Replacement: Schritt 3, Bild 3 von 3
    • Remove the four screws from the battery using a Phillips #0 screwdriver.
    • Pull up on the cable connected to the motherboard to remove.
    • Remove the battery from the bay.
  4. ASUS R554L Battery Replacement: Schritt 4, Bild 1 von 3 ASUS R554L Battery Replacement: Schritt 4, Bild 2 von 3 ASUS R554L Battery Replacement: Schritt 4, Bild 3 von 3
    • Place the new battery in the bay.
    • Install the battery cable to the motherboard, applying pressure in a downward direction.
    • Screws the screws back in using a Phillips #0 screwdriver.
  5. ASUS R554L Battery Replacement: Schritt 5, Bild 1 von 3 ASUS R554L Battery Replacement: Schritt 5, Bild 2 von 3 ASUS R554L Battery Replacement: Schritt 5, Bild 3 von 3
    • Align the backplate.
    • Starting with the upper right corner, apply pressure in a downward angle.
    • Repeat the process around the backplate until it's fully secure.
  6. ASUS R554L Battery Replacement: Schritt 6, Bild 1 von 2 ASUS R554L Battery Replacement: Schritt 6, Bild 2 von 2
    • Screw the backplate screws back in using a Phillips #0 screwdriver.
Abschluss
Once the new battery is installed, leave the charger connected to the laptop over night to ensure the battery is holding a charge
3 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team 4-49, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 4-49, Briggs Spring 2022
CSULA-BRIGGS-S22S4G49
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 101
Insgesamt: 7,665
