Zum Hauptinhalt wechseln
ASUS ROG G46VW Screen Replacement
Was du brauchst
  1. ASUS ROG G46VW Screen Replacement, Speaker Cover: Schritt 1, Bild 1 von 1
    • Gently pry the back hinge cover piece away from the device.
  2. ASUS ROG G46VW Screen Replacement: Schritt 2, Bild 1 von 1
    • Disconnect the speaker cable from the motherboard.
  3. ASUS ROG G46VW Screen Replacement, RAM: Schritt 3, Bild 1 von 2 ASUS ROG G46VW Screen Replacement, RAM: Schritt 3, Bild 2 von 2
    • Lift the screw cover and remove the screw using a Phillips #0 screwdriver.
  4. ASUS ROG G46VW Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the RAM cover by lifting the screw cover and pulling away firmly.
  5. ASUS ROG G46VW Screen Replacement: Schritt 5, Bild 1 von 2 ASUS ROG G46VW Screen Replacement: Schritt 5, Bild 2 von 2
    • Push outwards on the clips to release the RAM stick. The stick should pop up at an angle.
  6. ASUS ROG G46VW Screen Replacement: Schritt 6, Bild 1 von 1
    • Pull out the RAM stick carefully.
    • Do not use a prying motion as this will damage the hardware. Be careful not to damage the gold section of the RAM stick.
  7. ASUS ROG G46VW Screen Replacement: Schritt 7, Bild 1 von 1
    • Repeat steps 3-4 to remove the second RAM stick.
  8. ASUS ROG G46VW Screen Replacement, Keyboard: Schritt 8, Bild 1 von 1
    • Remove the two screws from underneath the RAM cover.
  9. ASUS ROG G46VW Screen Replacement: Schritt 9, Bild 1 von 1
    • Remove all of the screws from the bottom of the case.
    • If replacing the screen, remove the rubber feet to reveal two more screws.
  10. ASUS ROG G46VW Screen Replacement: Schritt 10, Bild 1 von 1
    • Turn the laptop over and remove the screws as shown
  11. ASUS ROG G46VW Screen Replacement: Schritt 11, Bild 1 von 1
    • Carefully pry the keyboard away using your spudger and the opening tools.
    • Be sure not to damage the clips holding the keyboard to the bottom case.
  12. ASUS ROG G46VW Screen Replacement: Schritt 12, Bild 1 von 2 ASUS ROG G46VW Screen Replacement: Schritt 12, Bild 2 von 2
    • Detach the ribbon cable by releasing the clip
  13. ASUS ROG G46VW Screen Replacement, Screen: Schritt 13, Bild 1 von 2 ASUS ROG G46VW Screen Replacement, Screen: Schritt 13, Bild 2 von 2
    • Remove screws from silver braces.
  14. ASUS ROG G46VW Screen Replacement: Schritt 14, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    • Use tweezers to remove golden screw caps.
  15. ASUS ROG G46VW Screen Replacement: Schritt 15, Bild 1 von 1
    • Remove tape and gently pull up on golden cap connectors to disconnect them.
  16. ASUS ROG G46VW Screen Replacement: Schritt 16, Bild 1 von 1
    • Gently pull the white connector until it comes loose.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ryan Riley
154 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 5
Insgesamt: 550
