Zum Hauptinhalt wechseln
Einleitung
If your battery is dead, or you need to take it out for any reason, take the following steps to remove it properly.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
  1. Make sure you completely power down the computer before beginning this process.
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. MacBook Akku Fix Kits
    Ab $69.99
    Buy Now
    Ab $69.99
    Buy Now
  3. Pull the battery out of its place gently.
    • Pull the battery out of its place gently.
Abschluss
Joseph Rockwell
243 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S11-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 7
Insgesamt: 110
