Zum Hauptinhalt wechseln
ASUS ROG G750JW-RS72-CB Display Assembly Replacement
Was du brauchst
  1. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Hard Drive: Schritt 3, Bild 1 von 1
    • Lift up the flap using a plastic opening tool.
    • Hold the flap back with your finger.
  4. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 4, Bild 1 von 1
    • Unscrew the 5.2mm screw underneath the flap.
  5. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 5, Bild 1 von 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  6. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 6, Bild 1 von 3 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 6, Bild 2 von 3 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 6, Bild 3 von 3
    • Unscrew the 5.2mm screws holding the hard drive in place.
    • Gently pull the rubber hard drive mount to the side.
    • Pull the drive out.
  7. ASUS ROG G750JW-RS72-CB Display Assembly Replacement, Display Assembly: Schritt 7, Bild 1 von 1
    • Remove the 8.5mm screws holding the bottom half of the laptop together.
  8. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 8, Bild 1 von 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 8, Bild 2 von 2
    • Take a metal separater and gently pry open the back end of the laptop halves.
  9. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 9, Bild 1 von 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 9, Bild 2 von 2
    • Remove the connector connecting the screen and the motherboard
  10. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 10, Bild 1 von 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 10, Bild 2 von 2
    • Unscrew the 6.8mm screws holding the hinges of the screen to the bottom half of the computer.
    • Detach the screen from the hinges of the laptop.
    • Be careful not to damage the connecting wires when detaching the screen.
  11. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 11, Bild 1 von 2 ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 11, Bild 2 von 2
    • Use a metal separator to carefully separate the bottom half of the laptop.
  12. ASUS ROG G750JW-RS72-CB Display Assembly Replacement: Schritt 12, Bild 1 von 1
    • Gently unplug the cables connecting the screen to the motherboard.
    • The display assembly can now be freely separated.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Sully Chen
525 Reputation
2 Anleitungen geschrieben
Cal Poly, Team S11-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
Super helpful.
Upon re-pasting GPU I noticed that not only GPU chip was covered in thermal paste surrounding chips were literately covered with thermal paste to is that normal?
Timepusher - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 21
Insgesamt: 2,183
