Zum Hauptinhalt wechseln
ASUS ROG G750JW-RS72-CB RAM Replacement
Was du brauchst
  1. ASUS ROG G750JW-RS72-CB RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Make sure you completely power down the computer before beginning this process.
    • With your finger, push this slide to the right. The battery should pop out of place.
  2. ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 2, Bild 1 von 1
    • Pull the battery out of its place gently.
  3. ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: Schritt 3, Bild 1 von 2 ASUS ROG G750JW-RS72-CB RAM Replacement, RAM: Schritt 3, Bild 2 von 2
    • Open flap in center and underneath you will find a screw, remove the 5.2mm screw with a Phillips #0 screwdriver.
  4. ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 4, Bild 1 von 2 ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 4, Bild 2 von 2
    • Once the screw is out, pull on the plastic tab to pull off the plastic cover.
  5. ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 5, Bild 1 von 1
    • This exposes two hard drive caddies.
    • This also exposes two RAM slots.
  6. ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 6, Bild 1 von 1
    • Push the metal tabs outward that are located on both sides of the top ram.
    • Remove the RAM from the slot.
    • Repeat with bottom RAM
  7. ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 7, Bild 1 von 2 ASUS ROG G750JW-RS72-CB RAM Replacement: Schritt 7, Bild 2 von 2
    • Align new RAM's key with the slot.
    • Place RAM in slot at a 45 degree angle downward, until the teeth are hidden inside of the socket itself.
    • Push down on RAM until a clicking sound is heard, meaning it is in place.
    • Repeat with top RAM
Abschluss
To reassemble your device, follow Steps 1-4 in reverse order.
Eine weitere Person hat diese Anleitung absolviert.
Ellie Moran
142 Reputation
1 Anleitung geschrieben
Cal Poly, Team S11-G5, Banghart Winter 2018 Mitglied von Cal Poly, Team S11-G5, Banghart Winter 2018
CPSU-BANGHART-W18S11G5
4 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
What about replacing the two internal RAM Modules?
Latiron London - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 26
Insgesamt: 1,494
