Zum Hauptinhalt wechseln
ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement
Was du brauchst
  1. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement, Internal Hard Drive: Schritt 1, Bild 1 von 1
    • Remove the six screws on the back of the laptop using a Phillips screwdriver.
    • Remove the back casing being held on by the one single screw. First lift the casing at the edge where the screw once was, then carefully lift at the rest of the edges to loosen the casing. Pull the casing towards the edge where the screw was.
  2. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: Schritt 2, Bild 1 von 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Locate the metal hard drive bay in the bottom left corner of the laptop.
    • Remove the two black screws securing the metal hard drive to the plastic.
    • Pull the tab to the right and slide to unseat the hard drive bay, then lift out.
  3. ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: Schritt 3, Bild 1 von 2 ASUS ROG G75VX-BHI7N11 internal Hard Drive Replacement: Schritt 3, Bild 2 von 2
    • Remove the two screws on the sides of the hard drive panel, shown circled. Repeat for the other side.
    • Replace the hard drive.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Logan Smith
783 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-3, Banghart Winter 2017 Mitglied von Cal Poly, Team 8-3, Banghart Winter 2017
CPSU-BANGHART-W17S8G3
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 4
Insgesamt: 1,034
