Zum Hauptinhalt wechseln
ASUS ROG Raikiri Pro Case Replacement
Was du brauchst
  1. ASUS ROG Raikiri Pro Case Replacement, Battery: Schritt 1, Bild 1 von 3 ASUS ROG Raikiri Pro Case Replacement, Battery: Schritt 1, Bild 2 von 3 ASUS ROG Raikiri Pro Case Replacement, Battery: Schritt 1, Bild 3 von 3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Remove the left handle-cover.
    • Repeat the steps to remove the right handle cover.
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS ROG Raikiri Pro Case Replacement: Schritt 2, Bild 1 von 3 ASUS ROG Raikiri Pro Case Replacement: Schritt 2, Bild 2 von 3 ASUS ROG Raikiri Pro Case Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    Frag FixBot
  3. ASUS ROG Raikiri Pro Case Replacement: Schritt 3, Bild 1 von 2 ASUS ROG Raikiri Pro Case Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    Frag FixBot
  4. ASUS ROG Raikiri Pro Case Replacement: Schritt 4, Bild 1 von 2 ASUS ROG Raikiri Pro Case Replacement: Schritt 4, Bild 2 von 2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    Frag FixBot
  5. ASUS ROG Raikiri Pro Case Replacement: Schritt 5, Bild 1 von 2 ASUS ROG Raikiri Pro Case Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    • Disconnect the ribbon cable that crosses over the battery.
    Frag FixBot
  6. ASUS ROG Raikiri Pro Case Replacement: Schritt 6, Bild 1 von 2 ASUS ROG Raikiri Pro Case Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to carefully remove the board and left rumble motor.
    Frag FixBot
  7. ASUS ROG Raikiri Pro Case Replacement: Schritt 7, Bild 1 von 2 ASUS ROG Raikiri Pro Case Replacement: Schritt 7, Bild 2 von 2
    Frag FixBot
  8. ASUS ROG Raikiri Pro Case Replacement: Schritt 8, Bild 1 von 1
    • Gently remove the battery from its enclosure.
    Frag FixBot
  9. ASUS ROG Raikiri Pro Case Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the right board.
    Frag FixBot
  10. ASUS ROG Raikiri Pro Case Replacement: Schritt 10, Bild 1 von 1
    • Use a spudger to carefully remove the right board.
    Frag FixBot
  11. ASUS ROG Raikiri Pro Case Replacement: Schritt 11, Bild 1 von 1
    • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
    • Use the widest tool possible to avoid damaging the delicate hinge pins.
    • Use tweezers or your fingers to gently pull the cable out of its socket.
    • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
    Frag FixBot
  12. ASUS ROG Raikiri Pro Case Replacement: Schritt 12, Bild 1 von 1
    • Using a Phillips #1 screwdriver to remove the six 8 mm screws holding the motherboard to the case.
    Frag FixBot
  13. ASUS ROG Raikiri Pro Case Replacement: Schritt 13, Bild 1 von 1
    • Use tweezers to disconnect the ribbon cable from the top of the motherboard.
    Frag FixBot
  14. ASUS ROG Raikiri Pro Case Replacement: Schritt 14, Bild 1 von 1
    • Remove the motherboard from the case.
    • Be careful when removing the motherboard so you don't damage the USB-C connector.
    Frag FixBot
  15. ASUS ROG Raikiri Pro Case Replacement, Case: Schritt 15, Bild 1 von 1
    • Flip the top case so the front is facing down and pop out the action buttons if they don't fall out.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 70
Insgesamt: 638
