Zum Hauptinhalt wechseln
ASUS ROG Raikiri Pro Joystick Cover Replacement
Was du brauchst
  1. ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: Schritt 1, Bild 1 von 3 ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: Schritt 1, Bild 2 von 3 ASUS ROG Raikiri Pro Joystick Cover Replacement, Joystick Cover: Schritt 1, Bild 3 von 3
    • Make sure your controller is completely turned off before proceeding.
    • Insert the tip of an opening pick into the seam of the top left handle cover.
    • Slide it down to release the clips connecting the handle cover to the controller.
    • Repeat the steps to remove the right handle cover.
    • Remove the handle covers.
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 2, Bild 1 von 3 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 2, Bild 2 von 3 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 2, Bild 3 von 3
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
    Frag FixBot
  3. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 3, Bild 1 von 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 3, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
    Frag FixBot
  4. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 4, Bild 1 von 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 4, Bild 2 von 2
    • Place the tip of an opening pick or spudger in the seam of the back center panel.
    • Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
    • Separate the top and bottom of the device.
    Frag FixBot
  5. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 5, Bild 1 von 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 5, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
    Frag FixBot
  6. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 6, Bild 1 von 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 6, Bild 2 von 2
    • Use a spudger to carefully remove the left board.
    Frag FixBot
  7. ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 7, Bild 1 von 2 ASUS ROG Raikiri Pro Joystick Cover Replacement: Schritt 7, Bild 2 von 2
    • Flip the board over and remove the joystick cover.
    Frag FixBot
Abschluss
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 19
Letzte 30 Tage: 84
Insgesamt: 785
