Einleitung
This guide shows how to replace the motherboard in a ASUS ROG Raikiri Pro controller. If your controller is not communicating with the device that it's plugged in or paired with, or if your controller is just completely failing, follow this guide for replacement.
A working motherboard should not only provide power to the controller but also work as communication pathways. Sadly not all motherboards last forever and might need to be replaced.
Since this guide will include the removal of the controller battery and if you realize that you have a swollen battery, please handle it accordingly before moving forward.
Before you begin the repair, make sure the controller is off and disconnected from the charger.
Was du brauchst
Insert the tip of an opening pick into the seam of the top left handle cover.
Slide it down to release the clips connecting the handle cover to the controller.
Remove the left handle-cover.
Repeat the steps to remove the right handle cover.
Use a Phillips #1 screwdriver to remove an 11 mm screw from the top of each handle.
Use a Phillips #1 screwdriver to remove an 11 mm screw from the bottom corner of each handle.
Place the tip of an opening pick or spudger in the seam of the back center panel.
Gently slide the pick from left to right along the seam to release the clips connecting the top and bottom of the controller.
Separate the top and bottom of the device.
Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the left board.
Disconnect the ribbon cable that crosses over the battery.
Use a Phillips #1 screwdriver to remove the three 8 mm screws securing the right board.
Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector—this is the unlocked position.
Use tweezers or your fingers to gently pull the cable out of its socket.
Using a Phillips #1 screwdriver to remove the six 8 mm screws holding the motherboard to the case.
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
