Zum Hauptinhalt wechseln
ASUS ROG Strix GL503VD-DB71 Fan Replacement
Was du brauchst
  1. ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: Schritt 1, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: Schritt 1, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement, Fan: Schritt 1, Bild 3 von 3
    • Flip the laptop over so that the bottom is facing up.
    • Remove the ten screws around the edges and in the center of the back case with a Phillips #1 screwdriver.
  2. ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 2, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 2, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 2, Bild 3 von 3
    • Pry up the triangular service cover with a plastic opening tool.
    • Remove the single Phillips #1 screw beneath the cover.
    • Pry up the remainder of the back cover with a plastic opening tool and remove the back cover.
  3. ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 3, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 3, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 Fan Replacement: Schritt 3, Bild 3 von 3
    • Remove the four screws from the fans with a Phillips #1 screwdriver.
    • Unplug each of the fan connectors from the motherboard.
    • Remove each fan by lifting it from the case.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
2 Kommentare zur Anleitung
Hi! I have a GL503VD-EB72 and my fans look ever so slightly different. Trying to replace one right now but I’m seeing a lot of variety in what’s available on eBay and amazon…How can I tell if my fans are 5V or 12V?
Kirsten M - Antwort Teilen
WTF i can find a 12 V for my GL503V
mrparisalexandre - Antwort Teilen
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 22
Letzte 30 Tage: 61
Insgesamt: 5,389
