Zum Hauptinhalt wechseln
ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement
Was du brauchst
  1. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement, M.2 Solid State Drive: Schritt 1, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement, M.2 Solid State Drive: Schritt 1, Bild 2 von 2
    • Completely turn off the laptop, lay it on a flat surface, and turn it over.
  2. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 2, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 2, Bild 2 von 2
    • Using a plastic pry tool, pry off the rubber tab to reveal the screw underneath.
  3. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 3, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 3, Bild 2 von 2
    • Using a Phillips #0 screwdriver, unscrew the one 2 mm screw that is holding down the compartment cover on the bottom of the laptop.
  4. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 4, Bild 1 von 3 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 4, Bild 2 von 3 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 4, Bild 3 von 3
    • With a plastic pry tool, carefully pry open the cover on the bottom of the laptop starting where the screw was located.
    • Once part of the cover is popped off, slide your pry tool around the edge of the entire cover until all the connectors unsnap.
  5. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 5, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 5, Bild 2 von 2
    • Locate the M.2 SSD and with a Phillips #0 screwdriver unscrew the 2.5 mm screw holding it down.
  6. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 6, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 6, Bild 2 von 2
    • With your hand, lift up the M.2 SSD and carefully pull it out of the connector slot making sure not to apply to much pressure.
  7. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 7, Bild 1 von 1
    • Take your new M.2 SSD and slide it back into the connector slot face up until it is fully in.
    • Some connection pads on M.2 SSDs are very fragile and can be broken easily.
  8. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 8, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 8, Bild 2 von 2
    • Take the 2.5 mm screw that was holding down the M.2 SSD and with a Phillips #0 screwdriver screw it back into the slot to hold down the new M.2 SSD.
  9. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 9, Bild 1 von 1
    • Take the bottom panel and align it so the shape fits to the opening.
    • Slide the left side of the cover back into the slot first so that the two extrusions fit into their openings.
  10. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 10, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 10, Bild 2 von 2
    • Carefully press down around all the sides of the bottom cover until all the connectors snap back into place.
  11. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 11, Bild 1 von 2 ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 11, Bild 2 von 2
    • Using a Phillips #0 screwdriver, take the 2 mm screw that was holding down the cover and screw it back into the opening on the cover.
  12. ASUS ROG Strix GL503VD-DB71 M.2 SSD Replacement: Schritt 12, Bild 1 von 1
    • Place the rubber tab back into its slot with the sticky side down.
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 26
Insgesamt: 7,287
