Zum Hauptinhalt wechseln
ASUS ROG Zephyrus M15GU205L Fan Cleaning
Was du brauchst
  1. ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: Schritt 1, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning, Battery: Schritt 1, Bild 2 von 2
    • Remove fifteen 10 mm screws from the bottom cover using a Phillips #0 screwdriver.
  2. ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 2, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 2, Bild 2 von 2
    • Use a plastic opening tool to separate the back cover from the laptop.
    • It is recommended that you separate the laptop cover from the side and run the tool along the edge of the cover to open it.
    • Be careful not to damage the cover when removing it from the laptop.
  3. ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 3, Bild 1 von 1
    • Remove six 4.8 mm screws that secure the battery using a Phillips #00 screwdriver.
  4. ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 4, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 4, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Disconnect the 8-pin battery that secures the battery to the motherboard.
    • Use the nylon tipped reverse tweezers to squeeze the edges, then pull out the connector.
  5. ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 5, Bild 1 von 1
    • Remove the battery from the computer.
  6. ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 6, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning, ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 6, Bild 2 von 2
    Microfiber Cleaning Cloths
    $3.99
    • Use the microfiber cloth to wipe any surface dust off the fan fins.
    • Wipe lightly as to not push any of the dust inside.
    • Wiping off the dust is optional.
  7. ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 7, Bild 1 von 2 ASUS ROG Zephyrus M15GU205L Fan Cleaning: Schritt 7, Bild 2 von 2
    • Use the compressed air to blow out the dust from the fan.
    • Use the information on how to correctly use the product you selected.
    • Use the air until you see the results you are comfortable with.
Abschluss
eli2243977
281 Reputation
2 Anleitungen geschrieben
Gateway, Team 69-69, Gonzalez Fall 2023 Mitglied von Gateway, Team 69-69, Gonzalez Fall 2023
GCC-GONZALEZ-F23S69G69
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 29
Letzte 30 Tage: 68
Insgesamt: 1,231
