Zum Hauptinhalt wechseln
ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement
Was du brauchst
  1. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Unfasten the lower case: Schritt 1, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Unfasten the lower case: Schritt 1, Bild 2 von 2
    • Remove the 11 Phillips screws securing the lower case:
    • Seven 11.6 mm screws
    • Two 14.6 mm screws
    • Two 6.1 mm screws
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Insert an opening pick: Schritt 2, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Insert an opening pick: Schritt 2, Bild 2 von 2
    • Insert an opening pick between the lower case and the chassis on the front right edge.
    Frag FixBot
  3. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Release the right edge clips: Schritt 3, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Release the right edge clips: Schritt 3, Bild 2 von 2
    • Slide the pick along the right edge to release the clips securing the lower case.
    Frag FixBot
  4. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Release the remaining clips: Schritt 4, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Release the remaining clips: Schritt 4, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Release the remaining clips: Schritt 4, Bild 3 von 3
    • Continue sliding the opening pick along the perimeter of the lower case to release the remaining clips.
    Frag FixBot
  5. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement: Schritt 5, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement: Schritt 5, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement: Schritt 5, Bild 3 von 3
    • Lift the lower case from the chassis and remove it.
    • During reassembly, this is a good point to power on your laptop and test all functions before sealing it up. Be sure to power your laptop back down before you continue working.
    Frag FixBot
  6. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Reposition the plastic: Schritt 6, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Reposition the plastic: Schritt 6, Bild 2 von 2
    • Use your fingers to move the plastic that covers the battery connector out of the way.
    • If the plastic is not staying out of the way use a piece of tape to secure it.
    Frag FixBot
  7. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Disconnect the battery: Schritt 7, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Disconnect the battery: Schritt 7, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Disconnect the battery: Schritt 7, Bild 3 von 3
    • Use the flat end of a spudger to push each side of the battery connector until it comes out of the socket.
    Frag FixBot
  8. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Unfasten the right SSD: Schritt 8, Bild 1 von 2 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Unfasten the right SSD: Schritt 8, Bild 2 von 2
    • Use a Phillips screwdriver to remove the 3.6 mm screw securing the right SSD.
    Frag FixBot
  9. ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Remove the SSD: Schritt 9, Bild 1 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Remove the SSD: Schritt 9, Bild 2 von 3 ASUS TUF Gaming F15 FX506HEB-DB74 Right SSD Replacement, Remove the SSD: Schritt 9, Bild 3 von 3
    • Pull the SSD out of its socket and remove it. Keep the SSD as parallel to the motherboard as possible when pulling on it.
    • Do not pull up at a sharp angle, as this could damage the SSD and the socket.
    Frag FixBot
Abschluss
Take your e-waste to an R2 or e-stewards certified recycler.
Repair didn't go as planned? Try some basic troubleshooting, or ask our ASUS TUF answers community for help.
Eine weitere Person hat diese Anleitung absolviert.
Spencer Day
196.130 Reputation
1.243 Anleitungen geschrieben
iFixit Mitglied von iFixit
Staff
123 Mitglieder
27.624 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 12
Letzte 30 Tage: 48
Insgesamt: 1,233
