Zum Hauptinhalt wechseln
ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement
Was du brauchst
  1. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: Schritt 1, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: Schritt 1, Bild 2 von 2
    • Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
  2. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 2, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Using a heavy-duty spudger, pry the back cover up from the frame and completely remove.
  3. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 3, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 4.7 mm screws with the Phillips #0 screwdriver.
  4. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 1 von 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 2 von 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 3 von 3
    • Using a spudger or fingernail, flip up the white plastic latch securing the ribbon cable.
    • After the latch is released remove the ribbon cable and clear it from the board.
  5. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 5, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the board itself by carefully pulling the board up then away from the rest of the computer.
Abschluss
Wyatt Scott
136 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Harley Fall 2018 Mitglied von IUPUI, Team S2-G3, Harley Fall 2018
IUPUI-HARLEY-F18S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 987
