Zum Hauptinhalt wechseln
ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement
Was du brauchst
  1. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: Schritt 1, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement, USB and Power Circuit Board: Schritt 1, Bild 2 von 2
    • Remove the ten 10.7 mm screws using a Phillips #0 screwdriver from the back of the laptop.
  2. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 2, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 2, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Heavy-Duty Spudger
  3. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 3, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 3, Bild 2 von 2
    • Remove the two 4.7 mm screws with the Phillips #0 screwdriver.
  4. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 1 von 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 2 von 3 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 4, Bild 3 von 3
    • Using a spudger or fingernail, flip up the white plastic latch securing the ribbon cable.
    • After the latch is released remove the ribbon cable and clear it from the board.
  5. ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 5, Bild 1 von 2 ASUS Transformer Book Flip TP500LA USB and Power Circuit Board Replacement: Schritt 5, Bild 2 von 2
    • Remove the board itself by carefully pulling the board up then away from the rest of the computer.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Wyatt Scott
160 Reputation
1 Anleitung geschrieben
IUPUI, Team S2-G3, Harley Fall 2018 Mitglied von IUPUI, Team S2-G3, Harley Fall 2018
IUPUI-HARLEY-F18S2G3
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 5
Letzte 30 Tage: 31
Insgesamt: 1,192
