Zum Hauptinhalt wechseln
ASUS U57A-BBL4 Display Assembly Replacement
Was du brauchst
  1. ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 1 von 2 ASUS U57A-BBL4 Display Assembly Replacement, Display Assembly: Schritt 1, Bild 2 von 2
    • Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
  2. ASUS U57A-BBL4 Display Assembly Replacement: Schritt 2, Bild 1 von 1
    • Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
  3. ASUS U57A-BBL4 Display Assembly Replacement: Schritt 3, Bild 1 von 1
    • Starting from one of the corners, use your fingers to pry the bezel from the screen.
    • There is a popping sound when the bezel is loosened from the screen.
  4. ASUS U57A-BBL4 Display Assembly Replacement: Schritt 4, Bild 1 von 3 ASUS U57A-BBL4 Display Assembly Replacement: Schritt 4, Bild 2 von 3 ASUS U57A-BBL4 Display Assembly Replacement: Schritt 4, Bild 3 von 3
    • Remove the top two 2 mm Phillips head screws.
    • Remove the four 2 mm Phillips head screws on the bottom.
    • Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
    • There are 14 screws in total: two on the top, four on the bottom, and four on each side. Use PH00 screw-driver for removing all 14 screws.
  5. ASUS U57A-BBL4 Display Assembly Replacement: Schritt 5, Bild 1 von 2 ASUS U57A-BBL4 Display Assembly Replacement: Schritt 5, Bild 2 von 2
    • Don't tear off the bottom of the screen or you might damage the connector cable.
    • Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
  6. ASUS U57A-BBL4 Display Assembly Replacement: Schritt 6, Bild 1 von 2 ASUS U57A-BBL4 Display Assembly Replacement: Schritt 6, Bild 2 von 2
    • Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
    • Gently slide the cable out of the ridges to free the screen from the casing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
UMass Dartmouth, Team S2-G4, Julie Fall 2017 Mitglied von UMass Dartmouth, Team S2-G4, Julie Fall 2017
UMASSD-JULIE-F17S2G4
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 263
