Einleitung
If your screen is cracked or not working properly, this guide will show you how to replace the screen on the ASUS U57A-BBL4.
Was du brauchst
Carefully pry the two rubber covers at the bottom of the screen off with a metal sprudger.
Remove the two 1.84 mm Phillips head screws at the bottom of the screen using PH00 screw driver.
Starting from one of the corners, use your fingers to pry the bezel from the screen.
Remove the top two 2 mm Phillips head screws.
Remove the four 2 mm Phillips head screws on the bottom.
Remove the eight 2 mm Phillips head screws on the sides of the screen. There are four on each side.
Carefully lower the screen from the casing with your fingers, making sure to keep the bottom intact and lay it face down on the keyboard.
Disconnect the connector cable at the bottom by loosening the adhesive tape and lifting up.
Gently slide the cable out of the ridges to free the screen from the casing.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
