Einleitung
If your laptop does not read CD's or DVD's properly, there might be a problem with the optical drive. The following guide will help you replace the optical drive.
Was du brauchst
Remove the two 2 mm Phillips head screws on each side on the bottom using PH00 screw driver.
Remove the one 2 mm screw underneath the black cover in the middle using the same screw driver.
Remove the three 2 mm Phillips head screws on the hard drive using PH00 screw driver.
Remove the remaining seven 1.8 mm Phillips head screws using the same screw driver.
Remove the six 2 mm Phillips head screws on the top edge of the laptop using PH00 screw driver.
Flip the laptop right-side up and open the screen.
Starting in a corner of the keyboard, pry the keyboard from the laptop using a plastic opening tool.
Remove the ribbon cable on the bottom of the keyboard by lifting up on the tape and pulling up.
Ein Kommentar
On my Asus U57A you only have to remove the one 2mm screw under the plastic cover on the bottom and the optical drive slides right out. This seems like a considerable amount of overkill to me.
