Was du brauchst
Use the Plastic Opening tool to pry the five slots up at the top of the keyboard.
Lift the keyboard enough to expose the two ribbon connectors (LCD flex cable and flex band).
Use the Plastic Opening tool to push open the two black clips on each side of the connecting cords.
Remove the cable after pushing out the two black clips.
Push out each end of the black clip with a plastic opening tool or nylon spudger to remove the ribbon cable.
Remove the cable after pushing out both black clips.
Remove the keyboard.
Remove the thirteen 5 mm J0 screws from the back of the laptop.
With the keyboard removed, use the spudger tool to pry around the edge of the laptop until it is free.
Use the spudger tool to unplug the two cords from the body by pushing on the tabs on both sides of the plug.
With the previous two cords unplugged and out of the way, you can work on unplugging the black cord.
Use your fingers to pull up on the clear tab, or use the spudger tool to push out both sides of the connector.
Remove the four 5 mm J0 screws surrounding the Optical Drive.
Remove the optical drive by pulling it out and away from the connector.
Use the Plastic Opening Tool to unplug the blue cord on the Motherboard.
Remove the five 4 mm Phillips head 5 mm long screws that have white arrows pointing to them with the screwdriver.
Lift the Motherboard with your fingers by reaching underneath the Motherboard and prying.
Remove the two 4 mm Phillips head 5 mm long screws from the fan using the screwdriver.
Using the Spudger, carefully remove the white connector and lift the fan out of the casing.
Slowly lift the motherboard up towards you being careful as to not rip any cords out of the bottom.
Using the Spudger, remove the connector towards the bottom of the motherboard.
Remove the motherboard from the casing.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
