Zum Hauptinhalt wechseln
ASUS VivoBook Flip TP501U Battery Replacement
Was du brauchst
  1. ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: Schritt 1, Bild 1 von 2 ASUS VivoBook Flip TP501U Battery Replacement, Keyboard Panel: Schritt 1, Bild 2 von 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Battery Replacement: Schritt 2, Bild 1 von 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Battery Replacement: Schritt 3, Bild 1 von 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U Battery Replacement, Battery: Schritt 4, Bild 1 von 2 ASUS VivoBook Flip TP501U Battery Replacement, Battery: Schritt 4, Bild 2 von 2
    • Remove the white ribbon cable shown by pulling on the blue tab.
  5. ASUS VivoBook Flip TP501U Battery Replacement: Schritt 5, Bild 1 von 2 ASUS VivoBook Flip TP501U Battery Replacement: Schritt 5, Bild 2 von 2
    • Remove the black cable found beneath the white ribbon cable that you just removed.
  6. ASUS VivoBook Flip TP501U Battery Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the battery from the motherboard by unplugging the wire bundle shown.
  7. ASUS VivoBook Flip TP501U Battery Replacement: Schritt 7, Bild 1 von 2 ASUS VivoBook Flip TP501U Battery Replacement: Schritt 7, Bild 2 von 2
    • Unscrew the 3/16 inch long screw that holds the battery to the chassis using a #00 Phillips Screwdriver.
    • Lift the battery from the chassis.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 28
Insgesamt: 2,054
