Zum Hauptinhalt wechseln
ASUS VivoBook Flip TP501U Hard Drive Replacement
Was du brauchst
  1. ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: Schritt 1, Bild 1 von 2 ASUS VivoBook Flip TP501U Hard Drive Replacement, Keyboard Panel: Schritt 1, Bild 2 von 2
    • Open the laptop until it is flat and lay it screen down.
    • Remove eight 9.6mm Phillips #00 screws from the bottom of the laptop.
    • Remove two 4.8mm Phillips from the corners of the device.
  2. ASUS VivoBook Flip TP501U Hard Drive Replacement: Schritt 2, Bild 1 von 1
    • Turn the device face up.
    • Use the plastic Opening Pick to separate the keyboard panel from the chassis that was just unscrewed.
    • Pull the panel away from the chassis CAREFULLY, as there are ribbon cables attached between the keyboard and internal electronics.
  3. ASUS VivoBook Flip TP501U Hard Drive Replacement: Schritt 3, Bild 1 von 1
    • With the keyboard panel pulled up, detach the two ribbon cables from the motherboard using the blue tabs on the cables.
    • Remove the keyboard panel completely.
  4. ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 ASUS VivoBook Flip TP501U Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Unscrew the five 4.8mm Phillips #00 screws holding in the hard drive mounting bracket.
    • Slide the mounting bracket towards the battery to disconnect the hard drive from the motherboard.
  5. ASUS VivoBook Flip TP501U Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Unscrew the hard drive from the mounting bracket.
    • Remove the hard drive from the mounting bracket.
    • At the time of guide creation, the hard drive was not in the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 18
Insgesamt: 1,580
