Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This Guide will accomplish how to remove the hard drive in the asus VivoBook S300C
Ersatzteile
Keine Ersatzteile angegeben.
  1. Remove the 10 screws on the back cover.
    • Remove the 10 screws on the back cover.
    • Some screws are missing from this system. You should take your own notes to make sure you put the correct screws in during reassembly.
  2. Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • Remove the hard drive from the laptop. To do this, the cable is taped to the hard drive caddy. Remove the tape from the cable and disconnect the hard drive from the motherboard.
    • I am also missing screws here. Take your own notes to avoid misplacing screws during reassembly. They should all be the same length.
  3. Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side. Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Remove the 4 screws holding the hard drive in the caddy. There are two screws on each side.
    • Reassemble the laptop by following the steps in reverse order. This is my first guide, so let me know what I did wrong so I can fix it.
Abschluss
3 weitere Nutzer haben diese Anleitung absolviert.
Cameron
9.954 Reputation
1 Anleitung geschrieben
Master Techs Mitglied von Master Techs
Community
294 Mitglieder
957 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 1
Letzten 7 Tage: 3
Letzten 30 Tage: 15
Insgesamt: 2,656
