Zum Hauptinhalt wechseln
ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement
Was du brauchst
  1. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement, Wi-Fi Card: Schritt 1, Bild 1 von 1
    • Place the laptop upside down so that the bottom panel is facing upwards.
  2. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: Schritt 2, Bild 1 von 1
    • Unscrew the following 10 screws
    • Eight 5 mm Phillips head screws
    • Two 10 mm Phillips head screws
  3. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: Schritt 3, Bild 1 von 1
    • Carefully peel the panel off of the bottom of the laptop.
  4. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: Schritt 4, Bild 1 von 1
    • Remove the one 3 mm Phillips head screw holding the Wi-Fi card in place.
  5. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: Schritt 5, Bild 1 von 1
    • Carefully slide the card out of its connection port by pulling it outward.
  6. ASUS VivoBook S300CA-BBI5T01 Wi-Fi Card Replacement: Schritt 6, Bild 1 von 1
    • Remove the black and white antenna cable connector wires by carefully pulling upwards on them.
    • Note that the black wire connects to "Main" and the white wire connects to "Aux".
Abschluss
Keith Rachels
595 Reputation
5 Anleitungen geschrieben
UMass Dartmouth, Team 3-4, Bhusal Spring 2016 Mitglied von UMass Dartmouth, Team 3-4, Bhusal Spring 2016
UMASSD-BHUSAL-S16S3G4
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 503
