Zum Hauptinhalt wechseln
ASUS VivoBook S400C Hard Drive Replacement
Was du brauchst
  1. ASUS VivoBook S400C Hard Drive Replacement, Remove the Bottom Cover: Schritt 1, Bild 1 von 1
    • Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
  2. ASUS VivoBook S400C Hard Drive Replacement: Schritt 2, Bild 1 von 2 ASUS VivoBook S400C Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Use a spudger or your fingers to go around and lift the edges and release the back panel.
  3. ASUS VivoBook S400C Hard Drive Replacement, Disconnect the Battery: Schritt 3, Bild 1 von 1
    • Using a spudger, lift up the plug connecting the battery to the motherboard.
  4. ASUS VivoBook S400C Hard Drive Replacement, Battery: Schritt 4, Bild 1 von 1
    • With a Phillips #0 screwdriver, remove the four 5.7 mm screws holding the battery to the laptop.
  5. ASUS VivoBook S400C Hard Drive Replacement: Schritt 5, Bild 1 von 1
    • Carefully lift the battery up and out of the device.
  6. ASUS VivoBook S400C Hard Drive Replacement, Hard Drive: Schritt 6, Bild 1 von 1
    • Remove the three Phillips #0 screws holding the the hard drive in place:
    • Two 3.8 mm screws.
    • One 5.7 mm screw.
  7. ASUS VivoBook S400C Hard Drive Replacement: Schritt 7, Bild 1 von 1
    • Pull left and lift out the hard drive.
Abschluss
Tiana Curry
85 Reputation
1 Anleitung geschrieben
UC Santa Barbara, Team S4-G4, Bator Fall 2019 Mitglied von UC Santa Barbara, Team S4-G4, Bator Fall 2019
UCSB-BATOR-F19S4G4
3 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 25
Insgesamt: 2,071
