Einleitung
The mSATA SSD is used as a cache for the HDD to substantially speed up disk operations and reduce boot time.
Was du brauchst
Flip the device over and remove the ten 5.7 mm screws with a Phillips #0 screwdriver.
Use a spudger or your fingers to go around and lift the edges and release the back panel.
Using a spudger, lift up the plug connecting the battery to the motherboard.
Disconnect the I/O Board ribbon cable from the motherboard.
Flip up the retaining latch with a spudger.
Grasp the ribbon cable by the blue tab and pull it straight out from the connector.
Disconnect the I/O Board ribbon cable from the I/O board.
Flip up the latch with a spudger.
Remove the ribbon cable to expose the SSD device.
Grasp the SSD by the sides and slide it out of the connector.
