Zum Hauptinhalt wechseln
ASUS Vivobook Q301LA-BSI5T17 RAM Replacement
Was du brauchst
  1. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unscrew the (10) screws on the bottom of the computer chassis using the JIS #0 screwdriver.
  2. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 2, Bild 1 von 2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slightly lift the lower case and push it toward the rear of the computer to free the mounting tabs.
  3. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 3, Bild 1 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 3, Bild 2 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 3, Bild 3 von 3
    • Remove the (6) six screws attaching the battery to the frame using the JIS #0 screwdriver.
    • Use the black plastic spudger to remove the battery from the device.
  4. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 4, Bild 1 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 4, Bild 2 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 4, Bild 3 von 3
    • Gently take the battery out of the laptop, making sure that all wires connecting to it are disconnected.
  5. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: Schritt 5, Bild 1 von 2 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement, RAM: Schritt 5, Bild 2 von 2
    • Gently pry this metal cover off the motherboard.
  6. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 6, Bild 1 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 6, Bild 2 von 3 ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 6, Bild 3 von 3
    • Now the RAM stick is exposed. Using two fingers, gently push the buttons to release the RAM stick
  7. ASUS Vivobook Q301LA-BSI5T17 RAM Replacement: Schritt 7, Bild 1 von 1
    • When you put in the new RAM, make sure to line up the connectors. Put the RAM in gently, as being rough with it can cause damage to the stick.
Abschluss
USF Tampa, Team S5-G1, Walkup Fall 2017 Mitglied von USF Tampa, Team S5-G1, Walkup Fall 2017
USFT-WALKUP-F17S5G1
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 19
Insgesamt: 1,337
