Zum Hauptinhalt wechseln
ASUS Vivobook S500CA Battery Replacement
Was du brauchst
  1. ASUS Vivobook S500CA Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn the device over to where the back plate is facing up.
  2. ASUS Vivobook S500CA Battery Replacement: Schritt 2, Bild 1 von 1
    • Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
    • Place screws where they cannot be lost as they will be used to replace the back plate.
  3. ASUS Vivobook S500CA Battery Replacement: Schritt 3, Bild 1 von 1
    • Remove the back plate by lifting it straight up.
  4. ASUS Vivobook S500CA Battery Replacement: Schritt 4, Bild 1 von 1
    • Remove 9 (.5 cm) phillips screws around the edge of the battery.
  5. ASUS Vivobook S500CA Battery Replacement: Schritt 5, Bild 1 von 1
    • Lift up the battery to reveal the battery terminal.
  6. ASUS Vivobook S500CA Battery Replacement: Schritt 6, Bild 1 von 1
    • Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Abschluss
Deric Huffman
101 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 16
Insgesamt: 6,043
