Einleitung
If your battery is not holding charge or is completely dead, follow the guide to replace it.
Was du brauchst
Use a Philips Head PH1 screwdriver to remove 10 screws (3 1cm screws and 7 .5cm screws) around the perimeter of the back plate.
Unclip the battery terminal by prying straight up on the sides of the connector to release the clip.
Fast fertig!
Abschluss
