Was du brauchst
Using a Spudger, gently pry up the keyboard.
Rotate the keyboard to face downward.
Pull out the blue wiring connection. Use tweezers to make it easier to remove.
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
Ein Kommentar
First step is wrong; attempting to prise out the keyboard will damage it. First step should be to remove the screws which hold in the keyboard.
