Zum Hauptinhalt wechseln
ASUS X42J Motherboard Replacement
Was du brauchst
  1. ASUS X42J Motherboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Metal Spudger
    $2.99
    Kaufen
    • Make sure your device is unplugged and turned off before proceeding.
    • Using a Spudger, gently pry up the keyboard.
  2. ASUS X42J Motherboard Replacement: Schritt 2, Bild 1 von 2 ASUS X42J Motherboard Replacement: Schritt 2, Bild 2 von 2
    Nylon Tipped Tweezers
    Kaufen
    • Rotate the keyboard to face downward.
    • Pull out the blue wiring connection. Use tweezers to make it easier to remove.
  3. ASUS X42J Motherboard Replacement, Disk Drive: Schritt 3, Bild 1 von 1
    • Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
  4. ASUS X42J Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Slide the disk drive out of the device.
  5. ASUS X42J Motherboard Replacement, Motherboard: Schritt 5, Bild 1 von 3 ASUS X42J Motherboard Replacement, Motherboard: Schritt 5, Bild 2 von 3 ASUS X42J Motherboard Replacement, Motherboard: Schritt 5, Bild 3 von 3
    • Remove all screws located on the bottom plate of the laptop, beginning with the three located underneath the disc drive.
  6. ASUS X42J Motherboard Replacement: Schritt 6, Bild 1 von 2 ASUS X42J Motherboard Replacement: Schritt 6, Bild 2 von 2
    • Rotate the laptop until it is sitting face up and extract all screws exposed by removing the keyboard.
  7. ASUS X42J Motherboard Replacement: Schritt 7, Bild 1 von 2 ASUS X42J Motherboard Replacement: Schritt 7, Bild 2 von 2
    Metal Spudger
    $2.99
    Kaufen
    • Pull up on the front panel using the spudger until the front panel separates from the bottom panel.
  8. ASUS X42J Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Unscrew and remove the marked screws.
  9. ASUS X42J Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Separate the connectors.
  10. ASUS X42J Motherboard Replacement: Schritt 10, Bild 1 von 2 ASUS X42J Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Remove the motherboard from the device.
Abschluss
Robert Martinez
217 Reputation
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 726
