Einleitung
The screen is one of the most important parts of a laptop, as you won't be able to see anything you're doing without it, which is kind of the point. The disassembly isn't too complicated, there's just a lot of screws that need to be removed.
Was du brauchst
Use the Phillips #0 screwdriver to remove the two screws on the back of the laptop.
Using the Philips screwdriver, unscrew the screws shown in the pictures.
Unplug the wire connecting the screen to the motherboard.
Eine weitere Person hat diese Anleitung absolviert.
