Einleitung
Use this guide to help you replace the motherboard or to get to other parts in the laptop. Don't forget to keep track of all your screws.
Was du brauchst
Slide the right lock button to the unlock position.
After it is unlocked, a red line will be visible.
While holding the left lock button in the unlock position, push the battery from the center away from you.
Look at the top row of the keyboard, you will see a space that has four latches holding the keyboard down.
Push the latch away from the keyboard using the spudger point.
While pushing the latches use a plastic opening tool and pull up on a key near it.
Continue along the rest of the keyboard until it is released at all four latches.
Push the keyboard away from the mouse track pad to unlock the bottom from the base.
Pull each end of the black ribbon cable piece towards the mouse track pad to unlock the ribbon connector piece.
Gently pull out the ribbon cable from the connector piece.
Remove the two 9 mm Phillips head screws with the PH0 bit indicated by the red circles in the picture.
Remove the 9mm Phillips head screw in the left bottom corner of the hard drive with the PH0 bit.
Remove two 3mm Phillips head screws, one located on each side of the metal casing holding the hard drive using the PH0 bit.
Lift up the black lock holding the ribbon.
Using the blue tab, pull out the ribbon.
Flip the laptop on its side so that the red line indicated in the pictures is facing upwards.
Close the laptop and flip it over.
Remove the six 12.5 mm screws Phillips head and the five 9 mm screws remaining with the PH0 bit.
Flip the device back over and open the laptop.
Using the nylon or metal spudger, gently pry off the panel by moving the spudger along the seam.
Pull up on the tape holding the tan cable in place.
While holding the tape push up on each side of the cable connector to disconnect it.
Remove the white and black wire.
The motherboard is not completely separated from the base of the computer.
3 weitere Personen haben diese Anleitung absolviert.
