Einleitung
It is possible that your battery has stopped working due to physical or electrical damage. A replacement batter will need to be purchased. After purchasing a new battery follow these steps to replace your broken battery.
Was du brauchst
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
Once you have removed all six screws carefully lift the battery out and dispose.
5 weitere Personen haben diese Anleitung absolviert.
