Zum Hauptinhalt wechseln
ASUS X502CA Fan Replacement
Was du brauchst
  1. ASUS X502CA Fan Replacement, Fan: Schritt 1, Bild 1 von 1
    • Use a Phillips #00 screwdriver to remove:
    • Eight 9 mm screws.
    • Four 5 mm screws.
  2. ASUS X502CA Fan Replacement: Schritt 2, Bild 1 von 1
    • Remove the keyboard cover panel by using a plastic opening tool to carefully pop off the clips around the perimeter.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Fan Replacement: Schritt 3, Bild 1 von 1
    • The keyboard cover panel is connected to the motherboard with ribbons; be careful not to damage them.
    • Lift the keyboard cover carefully.
    • Disconnect the keyboard and touch-pad ribbons using tweezers.
  4. ASUS X502CA Fan Replacement: Schritt 4, Bild 1 von 1
    • Remove the keyboard cover panel.
  5. ASUS X502CA Fan Replacement: Schritt 5, Bild 1 von 1
    • Fold up the black plastic arms securing the cables and disconnect them using tweezers or finger nails.
    • If these are not unplugged, the motherboard may shock you.
  6. ASUS X502CA Fan Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the remaining connectors using tweezers or your finger nails.
  7. ASUS X502CA Fan Replacement: Schritt 7, Bild 1 von 1
    • Remove the six 5 mm screws using the Phillips #00 screwdriver.
  8. ASUS X502CA Fan Replacement: Schritt 8, Bild 1 von 1
    • Flip the motherboard over and away from the screen.
  9. ASUS X502CA Fan Replacement: Schritt 9, Bild 1 von 1
    • Remove the two 5 mm screws with a Phillips #00 screwdriver.
  10. ASUS X502CA Fan Replacement: Schritt 10, Bild 1 von 1
    • Unplug the fan's power connector using tweezers or your fingernails.
  11. ASUS X502CA Fan Replacement: Schritt 11, Bild 1 von 1
    • Peel off the marked strip using your fingers.
  12. ASUS X502CA Fan Replacement: Schritt 12, Bild 1 von 1
    • Lift the fan up and away from the motherboard.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
David Conner
292 Reputation
2 Anleitungen geschrieben
Clemson, Team 14-1, Shirley Winter 2015 Mitglied von Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Mitglieder
5 Anleitungen geschrieben
2 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 2
Insgesamt: 7,835
