Zum Hauptinhalt wechseln
ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement
Was du brauchst
  1. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement, Palm Rest with Keyboard and Touch Pad: Schritt 1, Bild 1 von 1
    • Use the Phillips #00 screwdriver to remove the seven 90mm screws.
    • Use the Phillips #00 screwdriver to remove the four 50mm screws.
  2. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: Schritt 2, Bild 1 von 1
    • Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
    • Be cautious when pulling off the cover because there are cables you will have to disconnect before completely removing the panel.
  3. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: Schritt 3, Bild 1 von 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: Schritt 3, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
  4. ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: Schritt 4, Bild 1 von 2 ASUS X502CA Palm Rest with Keyboard and Touch Pad Replacement: Schritt 4, Bild 2 von 2
    • Lift Palm Rest away.
    • Replace with new palm rest.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 14-1, Shirley Winter 2015 Mitglied von Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Mitglieder
5 Anleitungen geschrieben
1 Kommentar zur Anleitung
there is no reason to disassemble the top-half of the laptop.
seanwilson684 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 22
Insgesamt: 2,051
