Zum Hauptinhalt wechseln
ASUS X502CA Screen Replacement
Was du brauchst
  1. ASUS X502CA Screen Replacement, Screen: Schritt 1, Bild 1 von 2 ASUS X502CA Screen Replacement, Screen: Schritt 1, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Remove plastic square covers on both bottom corners exposing the screws below using tweezers.
    • Remove the screws under the plastic square covers, using a Phillips #00 screwdriver.
    • Screws are black, 50mm in lenght with a 20mm diameter.
  2. ASUS X502CA Screen Replacement: Schritt 2, Bild 1 von 2 ASUS X502CA Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the trim from the monitor by using the Plastic Opening Tool to carefully pop off the clips around the parameter.
  3. ASUS X502CA Screen Replacement: Schritt 3, Bild 1 von 2 ASUS X502CA Screen Replacement: Schritt 3, Bild 2 von 2
    • Remove the four phillips screws (two on top and two on bottom) using the Phillips #00 screwdriver.
    • The screws are black, 45mm long and 15mm in diameter with a philips head
  4. ASUS X502CA Screen Replacement: Schritt 4, Bild 1 von 2 ASUS X502CA Screen Replacement: Schritt 4, Bild 2 von 2
    • Pop the screen out from the top and lay flat on the keyboard.
    • Do not pull screen away from keyboard, as it is still attached by a wire at the bottom.
  5. ASUS X502CA Screen Replacement: Schritt 5, Bild 1 von 2 ASUS X502CA Screen Replacement: Schritt 5, Bild 2 von 2
    • Peel off the clear tape that is securing the video cable connector using your fingers or tweezers.
  6. ASUS X502CA Screen Replacement: Schritt 6, Bild 1 von 2 ASUS X502CA Screen Replacement: Schritt 6, Bild 2 von 2
    • Unplug the screen using tweezers.
  7. ASUS X502CA Screen Replacement: Schritt 7, Bild 1 von 1
    • Replace the damage screen with a new one.
    • Replacing the bezel trim requires the bottom to be inside the ends of the hinge cover. Be careful not to break the bezel when doing this.
    • Removing the hinge cover has a chance of breaking the tabs that hold it on. Remove it carefully.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
Clemson, Team 14-1, Shirley Winter 2015 Mitglied von Clemson, Team 14-1, Shirley Winter 2015
CLEM-SHIRLEY-W15S14G1
5 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 20
Letzte 30 Tage: 68
Insgesamt: 3,703
