Einleitung
Replacing the Wi-Fi card itself is quite simple, however, they did not make it easy to get to. To remove the Wi-Fi card you will need to remove most of the internal parts of the computer. All pre-requisite guides are listed and shown above.
Was du brauchst
Use the Phillips #00 screwdriver to remove the seven 90mm screws.
Use the Phillips #00 screwdriver to remove the four 50mm screws.
Next, use the plastic opening tool to carefully pop off the keyboard cover panel.
In diesem Schritt verwendetes Werkzeug:Tweezers$4.99
Lift palm rest and unplug keyboard cable and touchpad cable using tweezers. After these two cables have been unplugged you can remove the keyboard cover panel.
Remove the four 5mm screws that attach the hard drive bracket using the Phillips #0 screwdriver.
Remove the four 5mm Phillips #0 screws attaching the bracket to the hard drive.
Use the plastic opening tool to flip up the small clamp and pull out the ribbon cable.
Use 1 or 2 plastic opening tools to push down the small black plastic clips.
Pull the board up and out.
Locate the I/O board on the left of the computer. Using the Phillips #0 screwdriver, unscrew the three 5mm screws to unhinge the screen, which will free the board allowing it to be removed and replaced.
Unplug the power strip connecting to the motherboard with your fingers or plastic opening tool.
Unplug the battery from the laptop in the upper right hand corner of the battery using tweezers.
Use the Phillips #00 Screwdriver to carefully remove the 6 screws holding the battery in place.
Once you have removed all six screws carefully lift the battery out and dispose.
Use the Phillips #0 screwdriver to remove the last five 5mm screws holding the motherboard down.
Use the plastic opening tool to unclip the two wires from the Wi-Fi card that are connected to the motherboard.
Flip the motherboard over and use the plastic opening tool to unplug the black and red wires from the motherboard.
Take out the 2.5mm PH #0 screw located on the top of the Wi-Fi card.
Lift the card up and pull it out.
1 Kommentar zur Anleitung
Thank you
What type of card should we buy? We have to be ready with the replacement to start to take the parts out.
Can you post a picture of the card so we can see the slot and read what is written on it. I know you have 2 pictures but the red circle cover the writing.
Do you know the slot type of that card? Is it PCI-E slot ?
Do you know if that computer can accept 802.11ac or 802.11ax card ?
Can you post a link to the card that you used as replacement or another compatible card?
