Zum Hauptinhalt wechseln
ASUS X533SA-BHCLN10 LCD Screen Replacement
Was du brauchst
Einführungsvideo
  1. ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 1 von 2 ASUS X533SA-BHCLN10 LCD Screen Replacement, LCD Screen: Schritt 1, Bild 2 von 2
    • Power off laptop.
    • Flip over the laptop so the model stickers are pointing towards the ceiling, and the back of the laptop is facing you.
    Frag FixBot
    Kommentar hinzufügen
  2. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 2, Bild 1 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 2, Bild 2 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 2, Bild 3 von 3
    • Carefully insert a plastic opening tool into the top edge of the plastic cover. Slowly run the tool along the top edge to allow several small plastic clips to release.
    • Lift the plastic cover off and set it aside.
    Frag FixBot
  3. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 3, Bild 1 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 3, Bild 2 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 3, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, remove the (2) two magnetic tabs covering the screws on the screen.
    Frag FixBot
  4. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 4, Bild 1 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 4, Bild 2 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Use a JIS #0 screwdriver to remove the two 4.5mm screws.
    Frag FixBot
  5. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 5, Bild 1 von 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Insert a plastic opening tool under the edge of the laptop lid.
    • Carefully pop out the sides of the laptop by running the plastic opening tool along the edge.
    Frag FixBot
  6. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 6, Bild 1 von 2 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Use a JIS #0 screwdriver to unscrew the four 3.5mm screws.
    Frag FixBot
  7. ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 7, Bild 1 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 7, Bild 2 von 3 ASUS X533SA-BHCLN10 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Carefully lift up the LCD screen.
    • Carefully remove the cable connecting the LCD to the laptop by popping up the white clip on the laptop and sliding the connector out.
    Frag FixBot
Abschluss
IUPUI, Team S2-G4, Harley Fall 2018 Mitglied von IUPUI, Team S2-G4, Harley Fall 2018
IUPUI-HARLEY-F18S2G4
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 47
Insgesamt: 803
